Bringing Chamonix to the Arizona mountains - making it mine and fixing the little things
Inside of my front fenders looked a lot like yours. Surface rust, no rust through. I used Fluid Film kit a purchased on Amazon.
Leaves a greasy coating that will last. I applied mine two years ago and it’s still greasy to the touch.
This kit includes a 19” tube with nozzle that helps reach in side the “triangle”.
Fluid Film 11.75 Oz Undercoating Protection Aerosol Spray Can Black 3 Pack, Rust Inhibitor and Prevention, Anti Corrosion Multi Purpose Penetrant and Lubricant, Extension Wand https://a.co/d/9WbnEeh
Nope… looks pretty good. If you wish you can spray some waxoil up there with a wand. But as our cars stay pretty clean and dry these days… subjective.
The engine bay I would treat with some Ospho. Very gently.
I’m a fan of the waxoil. You never know if you will be caught in a rainstorm
Yeah I ended up getting more cans of both the Eastwood rust converting paint as well as some waxoil stuff, all with spray wands. I’m gonna spray the paint first, then follow up with the waxoil and then forget about it while I enjoy the coupe!
One other small update: this is my first carb car and I was reading about vapor lock. Seems it’s more of an issue in heat (bad for AZ, especially after I get AC working), elevation (lower boiling point, bad for my home at 7000’), and bad for cars with a “puller” fuel pump in the engine bay (lower fuel line pressures). I read that one easy preventative move is to heat shield the fuel lines.
It seems my car has had the mechanical fuel pump replaced with an electric one mounted under the coolant reservoir. Maybe at some point I’ll relocate it closer to the tank but for now I just got a Velcro heat shield. I anchored it with a hose clamp where the line comes through from the wheel well. It’s not the prettiest install but I think it will be effective, and maybe I can clean it up some time when I have some hoses out of the way:
I like that idea! How did you get the 3 liters in there? Mine is an early coupe and doesn’t have the plugs on the inside rocker under the carpet. So I’m left with the little holes on the outside. I can get a spray wand in there but the spray bottles are expensive…
I thought they all had the white plugs on the inside of the sill. I learned something!
The sill has a few other larger openings that are somewhat accessible :
A pillar lower. behind the kick panel. If you chuck it in there, it'll fill the forward
B-pillar, behind the trim panel. at the bottom is a 5*3 inch triangle shaped hole. it drains in between the C-pillar block and intermediate sill, and then continues to seep down into the seam of the outer and most inner (vertical) sill.
in between the B and C-pillar there is access to the outer skin, if you chuck it in there, it will seep down into the lowest seam (outer skin to inner sill)
C-pillar, just in front of the Wheelarch there is an 1x3 cm rectangular opening; that leads to the inner sill to middle sill seam.
Here's a pic showing how the internals of the sill look like.
Left in the image is the A-pillar, and the reinforcement (fresh grey Walloth repair panel)
ZigZag part with holes is the intermediate, or middle sill.
Right of the image shows the B pillar reinforcement and how it's supported by the intermediate sill.
I had no issues with my Zenith carbs last July of 2024 when it was 95-100 degrees in Arizona and New Mexico (at 7,000’) on our CCCA drive with Dirk and friends. The Webers are more prone to heat soak and fuel bowl evaporation however.
Good to know, that makes me feel better. I had read several members having vapor lock and since it seems I have many of the risk factors, this shielding seemed like cheap peace of mind and insurance against getting stranded.
Next update: my car had a very old 30-pin iPhone connector coming from the console, and a Jbl amp in the trunk. I hoped it would be easy to plug in a newer wire but when I opened the console I found a complicated fm transmitter with the connector semi hardwired in. I ditched the transmitter because the quality is bad anyway, and put a Bluetooth receiver on the amp in the trunk.
Since I had the shifter surround off anyway, and this was one of the most worn parts of the interior, I decided to refresh it. Part of the wear was caused by rubbing when shifting the 5-speed into reverse. I know some people use a short throw kit to rectify this, but I have ptsd from laying on my back redoing the shift linkage in my E30 so I just dremeled off the edge of the console. It still touches a little but is way better than before. I went through 4 leather and vinyl materials trying to get the grain, sheen, and thickness to work. In the end I settled on one where the grain is bigger and more prominent than before. Next time I have it off (ac project?) I may send it to an upholstery shop and have the aluminum re-anodized, but for now I’m quite happy with my DIY results - it looks way better than before and doesn’t move the whole console with shifting to reverse.
Next project - what a headache!!!
I’m 6’5” and my knees keep hitting the wheel at 8:00 and 4:00 so I wanted to mount the seat back a couple inches.
First, upon removing the seat, I found that a prior owner/mechanic had stripped one bolt (rattling loose) and broken another, replacing it with a single sheet-metal screw. Didn’t feel very safe! I tried to remove the broken bolt with an extractor but it was so seized that it broke the welds holding the threaded section on! So now there are four sheet metal screws replacing two bolts.
Next I bought a 3/8” steel bar - partly because that is the minimum thickness of the chromed plastic spacer under the seat. By adding wood below the steel in the places where the plastic is thicker, I could replicate the plastic spacer - but at the advice of @HB Chris I decided to make the wood thicker at the front to provide thigh support without lowering the rear. I sanded and stained the wood to match the wood trim elsewhere, and drilled a shallow hole in the end to accommodate and cover the head of the bolt going down into the slider.
The only issue with mounting the seat 2” back on the steel bar and mounting the bar to the slider is the need to accommodate the bolt head/washer from the seat bolt. I played with the left -side slider and tried bolting into the seat through both the slider and the bar. I found that the bolt head would impact the roller a tiny bit and prevent the slider from going back by a couple millimeters, but that loss is no problem if the seat is mounted 2” back. Fine. I moved to the R side and…
THE SLIDERS ARE DIFFERENT!!!
It’s nearly impossible to see from the outside, but for some reason the German engineers put the rollers in very different positions inside the L and R slider. So on the R side, the bolt head would severely impact the rearward sliding. Very frustrating. Since I had everything made already, I decided to countersink the bolt head coming out of the seat, so that it wouldn’t impinge on the roller track. I drilled a little thickness from the slider bar and more from the steel bar to accommodate the height of the bolt head and washer, but still leaving 1/4” of steel bar for strength. Even so, I needed a washer thickness at the front to space out the bar from the slider.
If I had to do this again, I would probably keep the wood spacer at the thickness of the plastic, or even less, and then use spacers between the slider and the steel bar to achieve the raised angle at the front of the seat, similar to what @HB Chris did. It might look funny from the side but I could fabricate some sort of cover with chrome tape to hide all this engineering and there would be no need to countersink and hide the head of the bolt from the seat. However, since I had already done all the work for the wood spacer, I’m happy with this solution.
Looks great, and thanks for documenting the seat slider update. I can see the benefit of the slight rearward tilt to give thigh support. And since I can't remember seeing your seatbelt picture before, maybe you want to add it into the thread I started last month about options for seat belts, with or without retractors. Did you install those since that thread? If so, any thoughts would be great - many of us are still trying to figure out best options. Turns out that as an early Euro 1972 car, I don't seem to have the area hidden under the headliner to install any belts there, so may pursue Dan Wood's option.
Yes, I did add the belt holders based on that thread! This is @dbower’s solution and I copied it almost exactly. I bought these 4”
Rope guides from Amazon. Then I used a grinder to cut off one of the “shoulders” of the guide so it would fit on the shoulder of the headrest. I attached it using two stainless zip ties which are hidden under the seatbelt. I grinded off the screw head and glued it in place, for cosmetic reasons.
This seemed like the safest solution because it holds the belt securely up high. In the event of a crash, the vertical headrest supports might collapse down but the horizontal support bar is firm and should keep the belt from digging further down into the seat and the driver’s shoulder.
The open design of the rope guide makes installation easy (no need to detach one end of the belt to thread through) and allows you to remove the belt to fold the seat if needed. However the metal guides should keep the belt from slipping to the side of the seat in the case of an angled impact - that was my concern with @dan Wood’s velcro and leather arrangement.
It’s not perfect, but seems like the safest, most comfortable and least invasive option for a pre-74 coupe.
Thanks, that is a very thorough explanation. And i should have been more clear - the part of Dan's installation that I will likely copy is the retractor portion attached to a metal bar bent to pass alongside the armrest terminating on the original seatbelt end attachment point. I agree that this version of the shoulder attachment is a better option and also agree that in the event of a crash as long as it's not a direct hit on the passenger side (which might theoretically push you and the shoulder attachment off towards the side), this is a nice balance between safety and usability for folding the seat forward. I will likely follow your steps on this.
Yes the retractors are nice - especially to keep things organized when getting in and out. But I kind of like the quaint feel of the original “airplane buckle” belts so it’s not a high priority for now. The interior is so cozy that everything is within easy reach without leaning forward once i’m belted in. One other “mod” I added without posting on here is the double cup holder. Somebody else had posted this BMW part that is supposed to clip on the console, but also fits on the handbrake with a little electrical tape to snug it up. The part is NLA but somebody made a 3D print version that looks ok. I modified it by cutting a slot into the divider between the 2 cup spaces - that way I can carry my phone, or 2 cups/cans.
Yes, I had seen the cup holder and was going to ask about that. If you have a link to the stl file I may try it as well. I understand that for some (like the speakers that came with my car already installed in the rear shelf which I upgraded since the old ones were completely blown), these are cars to be enjoyed without any modern conveniences. Yes, except when you’re going on a longer drive, having a little water bottle and some music isn’t a bad thing.
Yeah unfortunately I didn’t print it myself. I bought it on eBay and couldn’t really tell that it was printed. Thought about returning it but ultimately it is functional (and easily removable) and looks good enough
So moving the seat back helped but my long leg still gets in the way of wheel a little. I plan to keep this car a while so I wanted the driving position *perfect* which meant moving the wheel out too.
This seemed like it would be easy. Just get longer bolts and put some spacers on them right? I checked and the horn button wire is long enough. Piece of cake.
Well of course nothing is simple. Apparently the horn button snaps into the hub and not into the hole on the wheel. That’s a problem. So I went to the hardware store and found a piece of abs plumbing with the exact diameter as the inner hub. Perfect! But… the outer diameter was too big to allow the spacers to fit around it. So I had to dremel 6 notches around it so it would fit within the spacers. At that point, cutting black plumbing, I figured I would also cut a pipe for the outside to cover it. In the end it works well. The look is ok, not a perfect match but not very noticeable either. The piano black of the plastic kind of matches the Nardi logo?
Lastly, I posted elsewhere that I had put some CSL stripes on. I don’t know how long I’ll keep them, but for now I’m enjoying the little dash of color and the racecar vibes.
Refurbishing the gold BBS wheels was way more trouble than I expected:
- I made some sanding mistakes on the lips and had to go back to 150 grit all the way back to 2000.
- I gave up on getting the centers powder coated and did a gold rattle can job instead, but had to redo that after brake clean melted my first coat. Apparently it’s not a good way to degrease before spraying the clear. Oops.
- threepiece.us sent me a bunch of wrong size bolts mixed in with the M7s, and forgot the nuts entirely. Their customer service has been very slow to respond so I had to reuse some old hardware. Stay away from that shop!
- I cut my face when the torque wrench slipped as I was torquing them down. Ouch.
- I was turned down by multiple tire shops before finding one that would mount my tires.
BUT I did finish them barely in time for my coupe’s first show! And I’m generally really happy with how they came out.
Before:
After:
Speaking of my car’s first show, I can’t recommend Concours in the Hills enough. It has been Arizona’s biggest show in recent years, with over 1000 cars and 50,000 attendees. It is hosted around the lake in Fountain Hills, which apparently has the 4th biggest fountain in the world? There were some nice bimmers and an amazing selection of Italians classics, race cars, supercars, etc.
Here are a few highlights:
Can you spot the coupe?
