I am trying to reroute the drains from my sun roof and c-pilar out of the rocker boxes. The sun roof is straight forward and an easy path to behind the rear wheel well. The c-pilar is tougher since the end of the drain pipe is just above the level of the wheel well and there is solid structure in the path. The only way I can see to do the job is find a 90 degree fitting for just off of the end of the drain pipe and then run the hose from the 90 to behind the rear wheel well. That will require drilling a hole in the support sheet metal between the c-pilar/rear quarter/wheel well metal. Any advice out there?
Thanks,
Mike
Thanks,
Mike
