I removed my calipers and rubber brake lines this weekend and thought I would mention a couple of things about the tools.
You need very good quality 11mm and 14mm flare nut wrenches. One characteristic they need, (especially on the 11mm,) is to be "flat" on both sides. Not "caved" in as in the wrench at the top in the photo below.
The reason is that where the steel line that attaches to the flexible rubber hose right after having gone through the front fender, there is a trapeze shaped clip which butts right against that 11mm nut. The wrench needs to be able to "grab" as much of the surface of that nut in order not to strip it. The "caved in" type of wrenches waste a good 1 or 2 mm before they actually grab the nut, thereby increasing the chance of stripping it dramatically. DAMHIK...
The good one at the bottom of the picture is a SnapOn. Of course...
