Can I pick your brains a bit??
I just installed a couple of Weber 38/38s onto my new sport motor, 3.3L w/ a 300 cam & 9.3 compression. (Hurray! Finally my new motor got swapped in the Coupe!) Carbs are jetted at stock/baseline (145 mains, 185 Air correctors, F50 emulsion tubes & 45 Idle jets). Motor runs like watch but experiencing some air/fuel mixture issues, currently adjusted rich to be safe.
Currently, car has no oomph up to 2k RPMs, cruises fine from 2k to 4k, then flattens out at 4k......I assume this a air/fuel mixture or jetting issue.
I realize the cam/power band should come on later around 3500-4K and sore to 6k. The head was rebuilt/mod'd by Terry Tienney (Livermore,CA) and am confident in his work/reputation.
I realized that this issue would be best solved on a Dyno but considering the Coupes new 'home' (steep drive way & very hilly terrain), I'm not sure I can get her up & out of her new 'home'. She bogged down heavily up a steep hill in first gear and barely made it up....couldn't get the RPMs past 1800.....my ol' 2.8L had more balls than my hot 3.3L currently... :cry:
Coupe cruised just fine from Monterey to the East Bay but bogged heavily in the steep hills after the relatively flat freeway cruise home. Could the plugs have fouled that much in a two hour drive?
Any wisdom for a home tune appreciated (so I can 'get' to the Dyno/experts later), I don't want to see another 'flatbed' for long time.
TIA
-shanon
'70 2800cs (very manipulated)
BTW: Operation: Arctic Wind a success! What a battle! Re-cored (3) high-flow radiator, new water pump, 2500 cfm Aux fan, mod'd thermostat...(and a new sport motor. :twisted
she's running ice cold now, maybe a bit too cold, but she's desert proof now.
Lesson: If your having cooling issues, get the radiator pressure tested first! Could save you a lot of time and $$.
TIA
-shanon
