Cam I.D.
Mot27cars
Elkhart, IN
I know this had been discussed ....
However what does this #8 mean on the end of this cam?
autokunst
Milwaukee, WI
I don't have any input on what the #8 means. However, my rear cam cover is the source of a pretty hefty oil leak on my engine. So I plan on removing it and I can't wait to see if there are any markings on my cam. A PO had done some work on the engine, including piano top pistons. I assume the cam was changed at that time, but have no proof (yet). Watching with interest.
Mot27cars
Elkhart, IN
When you put the cover back on make sure to place the bolt with the heavy washer at the proper location. If you look you’ll see the gasket has one location that will allow oil to leak.
autokunst
Milwaukee, WI
This is great info. I'd ordered the gasket already but am not sure if it came with a separate bolt seal. I'll know more once I peel the onion.
stphers
No it won't come with the gasket, it is a separate part 2002's use the same seal at the dist drive housing # 12110002735
Also make sure that the plate is nice and flat Too many people end up over tightening up the bolts to try and stop leaks that the holes in the plate become deformed slightly and will cause leaks
Markos
Seattle, WA
Was hoping that @stphers knew the specs on this one. Our resident expert @sfdon isn’t familiar with this one. He has a big shelf full of cams and has regularly commented on the codes.
I think I’ll check mine this weekend. My car is alleged to have a “hotter cam” also.
Mot27cars
Elkhart, IN
All else I could find out today;
Evidence of red paint on shaft on the end away from cam gear.
1250057
2
3478
