sreams
So... a while back I installed a low-mileage M30B35 into the 3.0cs. I removed the fuel injection system and kept my downdraft Webers and old distributor. In order to keep things simple and inexpensive initially, I kept my old exhaust manifolds in order to mate directly to my existing downpipes.
The old M30 manifolds have (about) 1.5" ID outlets. From there, my exhaust system went from dual 1.5" pipes to a single 1.875" pipe. After that there was a long, thin muffler, more 1.875" pipe, a resonator, and finally 2.125" pipe.
Here's the old system out of the car:
http://www.roadrec.com/oldexhaust.jpg
I pulled the whole system out a few days ago, and installed the stock M30B35 manifolds and downpipes. The manifold outlets and pipes are about 1.875" ID, which means a whole lot more volume than the old 1.5" system. I then went to the local Marco Muffler and went over what I wanted in detail with the guy there. They installed a 2.5" system with three Magna Flow cylindrical mufflers and did an -amazing- job.
Here are pictures, from front to back:
http://www.roadrec.com/e9exhaust1.jpg
http://www.roadrec.com/e9exhaust2.jpg
http://www.roadrec.com/e9exhaust3.jpg
http://www.roadrec.com/e9exhaust4.jpg
The car sounds great... but more importantly, I honestly feel like I've got 40 more hp. It is a night and day difference in power delivery, especially above 3k rpm.
I had read here and elsewhere that M30 engines really like to breathe on the exhaust side, and my experience supports that.
Here's the system in action:
http://youtu.be/VgX6Lc2CmdE
For those who may have followed my previous threads about Weber DGV jetting, here's the current setup with the new exhaust. I'm using a wideband O2 sensor and gauge to assist in getting it really right:
Primary
60 idle
140 main
160 air
Secondary
55 idle
110 main
160 air
This gives me a solid 12-13:1 at WOT throughout the rpm range. I'm surprised that others on this forum are using much larger secondary main jets than I am. I wonder what is different about my setup, if anything.
-Scott
Primary
60 idle
140 main
160 air
Secondary
55 idle
110 main
160 air
-Scott
