Yes I did. My plan was to install my gauges in the speaker location then source another grill so I didn't have to jack up my original one. After consideration it would take a fair amount of working the grill to get it to fit flush because of the inner frame behind the cloth.
I wanted to be able to keep stock appearance when desired but after installing the VDO Series 1 gauges I ended up loving the look so I blew off the stealth project.
I have not found that checking the gauges when driving is a problem, not much longer than looking at the stock temp gauge and certainly less than the radio.
Anybody given any thought to putting the gauges behind the speaker grill? I have seen gauges mounted at that location but always exposed. I have wondered about placing a few gauges there and fit the grill over it to make it look more original ... And maybe put a sub port there for connecting an I phone / iPad
Another thought about gauges at the radio delete or on a panel such as was drawn a few posts below. I get the discussion about the a/c switch being too deep ... But if you were doing a custom panel, give some thought to the e12 approach where there was a ring switch around the clock. It's a really cool approach
