Check out the M30 motor in the Marvel Mystery Oil description...
rblongboarder
Southern California
I thought this was interesting..
That is definitely a M30 motor... an early model too.. the oil cap is close to the radiator, in comparison to later models where it's by the firewall.
That picture is rather wonky. You can see the starter, which means the intake manifolds are not present. And he's neither using the oil filler cap nor the dipstick tube (that's on the other side of the engine). It appears he's putting the Marvel Mystery Oil onto the exhaust manifolds.
I believe the picture depicts someone adding MMO directly into the cylinders via spark plug holes. As one would do to an engine that has not been run in years and/or has become stuck. I’ve done it.
Also, intakes and radiator has been removed. Pretty funny.
Recently a long time BMW mechanic told me MMO is a good gas tank additive to combat the negative effects of ethanol fuels.
One of the local car guys swears by this stuff. Has an old very nice GTO and uses Marvel Mystery Oil with every tank.
I used to use it with my 91 Montero and definitely noticed better running with it. I still use it here and there for various applications.
