Awesome. Does holding the pressure after shutdown prove the carb float valve and check valves are working perfectly? For how long does it hold it?
That will cost you about $6.50/kWh. Of course, that is assuming you have an ideal alternator.
I apologize, it is not just you! I do have two relevant questions.
1. Have you checked your leak-down with the new gauge installation?
2. Where did you source your check valve?
2. Thanks for the info. I will check with W&N.
1. Leak down: When you turn off the engine, how much time elaspes before the pressure gauge reads zero?
DeQ, what is that around your oil filler cap?
