Clutch master inlet seal
30csl
London/Herts
I have a weep from the seal which the brake fluid feed pipe goes into in the brake master cylinder. Does anyone know if this seal can be purchased on its own? It is a 1974 left hand drive e9.
Thanks,
Rohan
deQuincey
Quousque tandem...?
Thanks,
Rohan
caution, there are at least two sizes on the master cyl,
i recall you can buy fron the dealer
regards
viphoto
Carlsbad, CA
deQuincey
Quousque tandem...?
now i see a bit of misunderstanding, title says clutch, thread says brake
in any case if it is the original clutch is 17 mm in diameter, so 17x6,5 is the one, buy some, it is the same size as the original brake master cyl, i would buy at least 3, and it is a PITA to assemble the clutch one, so buy one more just in case
Cornishman
Essex, UK
I rebuilt my clutch master cylinder, it then failed. So I replaced it with a copy part that was very cheap. SF Don recommended replacing it, there is a thread on it somewhere.
The copy part was about three times the cost of the seal kit, so I would recommend the entire part and save the hassle.
C
