Coolant Capacity
Catbert
"Nothing happens until something moves."
Signal Hill, CA
From research I found that our CS coupes take 12 liters of coolant. When I drained mine I didn't bother to measure what came out. This weekend, I was finally able to complete the flushing process and fill it with fresh coolant. I mixed each liter of coolant and water and added it one liter at a time. To my surprise, it was full at only 11 liters. I ran the engine with the cap off the coolant reservoir and massaged the hoses to release any trapped air. I then drove the car around the block. After letting the engine cool, I checked the level again, but it remained at capacity. So, is 12 liters only an estimate or do some cars only use 11 liters as my Euro-spec CSi does?
12L is correct for CS and CSi as there is no difference, if you are full you are good to go. I use distilled water and Blue Coolant, whether BMW, Zerex or Peak. E3 is the same volume as well.
If one liter remains even when removing the engine coolant plug and, of course, removing the radiator lower hose, then that explains the "missing" liter of coolant. As @HB Chris said, "Full is full." :cool:
