coolant flow diagram with carb mods
autokunst
Milwaukee, WI
Not sure if I will phrase this question correctly, but does anyone have a successful coolant flow/hose layout/diagram for a car that has triple side draft carbs? Seems once the manifolds are swapped from original, and the carbs do not require water/coolant for the choke, things begin to change. I am trying to do some homework to ensure the entire block and head (especially at the rearward cylinders) flows well and stays cool.
Thank you in advance!
Ohmess
I wanna DRIVE!
Aiken, SC
Seems my prior posts on this have been lost to the Photobucket fiasco. Here is my original installation, following Steve's suggestion on the 635 hoses:
The heater shut off valve did not work in that location, and was relocated as shown here:
autokunst
Milwaukee, WI
Pictures are worth 1,000 words - thanks for re-posting!
I am sure this is also covered elsewhere, but since we're right here: source/origin for the heater bypass? I wasn't planning on using one, but I think it makes sense. I remember seeing a post from Rob Siegel on this, too.
