See my separate detailed reply with questions to heater bypass thread started by the hackmechanic. I need to verify which direction the coolant flows in/out of heater core in a 2800cs with zenith carbs.
On the 2800 a hose goes from back of cylinder head to bottom connection of the heater core. A second hose come from the top connection on heater core to the bottom of the rear carb base.
Does the flow come from the back of the cylinder head in/out the core then to the carb base or is it the other way around with the flow coming though base of carb in/out of core and into rear of cylinder head?
Which is it?
jjs 2800cs.
Which is it?
jjs 2800cs.
