Hi,
I´m trying to connect the original D-Jet Wiring harness to an overhauled 3,0l engine these days. The harness plug for engine cooling temperature seems to have the same plug connector as the injectors, but my temperature sender only have one spade/male connector.
Checking part number 62110788115 on the net gives several results, both with single connector and double connector (earth + signal). If ordering one it could be a gamble.
In addition to this the engine harness (not the D-Jet harness) also have a connection to the sender. This is the ordinary single type. Can it be mixed with the D-Jet harness?
I have a spare thermostat housing with several options for senders laying around. It might be an alternative to have two, one for the ECU and one for the temperature gauge?
Does anyone have any advice to share?
