Greetings All! I am reassembling my engine, and am I at the point where I want to reinstall the spray bar to the cylinder head. As you can see these pictures there is quite a difference between using a 1 mm thick, aluminum crush washer and using two of them in effect 2 mm. It seems like the oil feed hole in the banjo bolt lines up better with the spray bar cavity using two washers versus one. Any guidance or help would be greatly appreciated!
