Hi All,
I would like to get some advice.
Situation: car has run perfectly for many km's, but suddenly start to stutter.
Have cleaned the carbs, vacuum is all okay. Have replaced ignition with 123igntion. Also the alternator has been revised.
Car runs for 5 km better (still a bit slow on acceleration) but after a while stuttering is back. Even to the extent I hear sometimes the firing in the exhaust.
Question: as I have done all cleaning and have seen the jets are clean and the acceleration tubes also etc, could it be related to an electric issue ? Mass somewhere playing up or other ? Any help appreciatted.
Thanks, Niels
Since I am not that familiar with the 123ignition you installed, I resisted commenting on your problem.
Upon first impression, some of your problems seem like textbook fuel starvation issues, possibly due to a weak fuel pump or even clogged fuel lines. Carburetors can be problematic, but from what I have read, your symptoms do not seem to point directly to the carbs. Frankly, if the carbs had issues, including low float levels or floats that stick, or plugged fuel or air passages, I would imagine the problems would reveal themselves under most driving conditions and not after traveling a decent clip.
The fact that the problem evidently occurs after driving a lengthy distance, also suggests something heat related. On that note, a weak ignition coil will often mimic a weak or failing fuel pump. A weak coil will often demonstrate its weakness after it heats up. You did not mention anything about the coil or whether it is fed voltage via a traditional ballast resistor. The latter may be almost indestructible, but ceramic can break and metal can fatigue. I omitted any diagnosis of the 123ignition. It probably does a great job even when matched with a sub par coil. But, to the best of my old school thinking, it still needs a coil to function - properly. Hint, don't overlook either the coil or the ballast resistor that might possibly feed it. Even if the coil does not rely upon an external ballast resistor and looks pretty enough to adorn a wedding cake, it would be simple enough to swap it with another known-to-be-good coil to eliminate it as a possible culprit.
