Roll or not to roll
What fits is the question..., I have set of 16 x 8 et 21's that will take some creativeness to make them fit in the front, my goal is get a 225 55 16 to fit no stainless arches though. The arches you speak of will probably fit one you roll the inner fender, but it may take some messaging of the stainless arches also i suspect, the attachment points my need to be changed as I believe they attach to the fender using screws, and if you roll the fender that attachment point is now gone, you could use urethane adhesive to glue on the arches, but i think you will still need to trim the stainless arches some to accommodated that tire/rim size... Good luck, and some folks say stock is always better unless your racing it....!
