dash removal
aearch
Deceased
pleasant hill , ca
so i had to take out my dash to confirm all my wiring and set the guages
it seems one could take out the dash with the windshield in
as the clips can be turned 90 deg and removed from the bottom
then i would slide straight out
as i did it as a test
resetting the clips it tricky but possible as i have a long handle set of vic\ve grips
to compress the clip
Cool. I've read that it is possible. I'll get some pics of the dash removal. I also have an inspection can that can show the clips installed. Hope to start on the dash in late October.
the center is easy as from the front speaker
this car is amazing ive had to redo things three times in some cases
like a nut i set one of the side dash screws
so luckily got it out by gently moving the inside trim
just enuf to pull it out
