Differential Noise
So no noise in neutral?
I had some torque converter growl on the 4 speed auto ZF. Disappeared with a different torque converter.
What about the center bearing?
These types of dilemmas are of the type where I some times choose to ignore it. Perhaps it will disappear, likely it will grow worse. Benefit: when it becomes more noticable, it will also be easier to find!
Chris - I would redo the pre-load on the center bearing in the drive shaft. Relatively simple to do in isolation from other changes, and this fits with the noice being more pronounced inside the car.
