Dip Stick Tube Weeping
NewSixCoupe
Northeast
I assume there's an O-ring in there? Its not shown on Diagram 11/28? And how difficult is this fix? Thanks.
deQuincey
Quousque tandem...?
is the dip stick tube the one that holds the oil level bar ?
where do you think is the o-ring ?
can you show the 11/28 diagram ?
the tube i mention is stuck into the engine block, there is no way to place an oring there, just pressure
maybe you are asking about another tuebe ?
The tube is a press fit into the block, no o-ring but you can use a sealant. The dip stick itself has a rubber bellows that is part of the stick that fits into the tube, not a separate part number though.
NewSixCoupe
Northeast
OK, so no O-ring; thanks for confirming, Chris. The weeping is coming from the base of the tube, not where the dip stick bellows meets the tube. Is it worth ordering a new tube? I'm concerned about removing the original without breaking it! What type of sealant would you recommend?
restart
KANADA, Roberts Creek, BC
FWIW, here is what the factory tool for tapping it back in looks like...
