Thanks. Is there any advantage to a multi spark system?
It appears you have the correct dizzy with advance and retard vacuum lines and are good to go but make sure. Early coupes had advance only and take a different Pertonics unit.
Pertronix being more optimal from a maintenance standpoint of not have to adjust points, dwell, and timing. My personal opinion is that even points cost more money so going to a Pertronix or similar is a good solution. Cost less over time and better running for less maintenance. I run points- I don't mind the tune ups and I have a stash of them which will run out sometime.
