This DIY is subject to editing. More posts are being reviewed and information will be added.
I have tried to credit the people for their original posted information.
If there are errors or lacking information in here please let me know.
Air Conditioning Compressor and Bracket Selection
Posts were searched for this DIY:
e9coupe.com
@Stevehose did a great write up in 2011 as follows and some info was used:
e9coupe.com
Book by Rob Siegal "Just Needs a Recharge: The Hack Mechanic Guide to Vintage Air Conditioning."
Sanden Compressor and Mounting Bracket
The wing cell bracket (dimensions shown below) is part # 64-52-1-284-953 might be found on eBay or try Al Taylor - [email protected] @rsporsche
Might have to grind some of the wing cell bracket to allow it to lay flat against the block as it might interfere with the rib on the block. @Dan Wood
Others have had to shim the compressor bracket to the wing cell bracket. @Luis A.
L.C. Wylie & Co. Sanden Compressor Bracket https://lcwylieco.bigcartel.com/
1974 only - 74 is the only year with this unique bracket and compressor, part # 64 52 1 272 240. The original compressor has a mounting ear on the very top and vert bottom. @HB Chris
Compressors
-switch from old York boat anchor to "Sanden style" 709 compressor and York mounting bracket from Johnjoysyl eBay seller ($190 for both and must be at least a 15lb weight savings): @Stevehose (Steve has later recommended the L.C. Wylie & Co bracket per above)
508 or 709 works just fine. There's a lot of variations of both, different fittings and different sized pulleys etc. This is the one I like. A 709 with a 125mm pulley. Larger pulleys work (132mm I think), but can make installing the bolts more difficult. The 508 has 5 pistons and the 709 has 7. There's very little functional difference, I've used both with great results. But in theory the 709 is the "better" one, so I usually go with it if the price is about the same. @Layne
We buy from authorized Sanden dealer. I don't buy knockoffs because I have to replace them for free when they fall apart.
VINTAGE AIR DOCK 04808-VUA COMPRESSOR A/C SD-508 134. You want bling- buy the chrome model Bling-Bling @sfdon
Following are examples of where to buy the compressors:
https://www.summitracing.com/parts/vta-04709-vua @Layne @Stevehose
@Rex Kapriellian
Compressor Belt
***************Looks like the best belt choice is either 9330 or 9335 (see below)************** However, several lengths will work.
For AC I used Gates XL9345 (12.5/13mm x 885mm). I have an unknown (not stock- looks kind of like yours) compressor mounted on one of Layne's brackets. @TedS
Optional Belt Numbers same as XL9345 @Dan Wood
12/12/2021 For Sanden 508 with Layne's bracket
And the winner is...9335 (same as the one Chris has on his E12 with the same bracket and compressor as I have). I think the last three digits are the length of the belt in 10ths of an inch....so a 33.5" belt. I think Steve's Napa 25-9330 would probably work also. per @Dick Steinkamp
Non original pulley options will require different belt lengths.
Sanden compressor conversion brackets
Hello all, I have a very small one-man BMW restoration shop that I call L.C. Wylie & Co. and I also make and sell these brackets to convert your air conditioner to a modern Sanden type compressor. The original compressors are inefficient, expensive, and very hard to find a reliable new or...
e9coupe.com
Air conditioning upgrade photos/details
For those contemplating such a project, I recently completed my York to rotary a/c compressor upgrade. Keeping with R-12. In prior posts on this subject there weren't a lot of specifics so I am trying to offer some here for the novices like me. Project included: -switch from old York boat...
e9coupe.com
Compressors
Compressor Belt
