I've come across some nos Bilsteins, still in their boxes, but maybe a couple decades old. Are they likely to preform as new, or be in need of renewal of rubber parts, etc? Thanks, Paul
Were they stored upright? That may make a difference.
Bilsteins are gas filled not hydraulic so perhaps not.
That seems to indicate there is no hydraulics in Bilstein shocks. Can you clarify.
Are there not two varieties, HD which can be used with regular/OEM springs and Sports which require shorter springs? Both have the same dampening specs though some think the Sport are stiffer.For Bilsteins the dampening effect is handled by gas compression vs. the hydraulic fluid displaced in the OEM shock. This is why a different spring is required when changing to Bilsteins because the ride height is affected due to the longer travel and/or compression rate of the Bilstein.
