rb1971
I have a bit of an odd issue and thought there might be some institutional knowledge among the folks here.
My car has been back together and back on the road for a few months. As part of the restoration process, we refreshed and where necessary replaced all the power window equipment, and had the doors readjusted and realigned by a body shop which generally does great work and has done a fine job on my car overall.
The passenger side front window has never worked as well as the other three windows (which all work consistently and well, if not quite as fast as on a modern car). The main issue seems to be that in the fully up position, the chrome below the rear window interferes with the passenger glass, so that you can't really put the window up the last 1/4". I've seen a few coupes where the bottom of the glass was scalloped out to prevent exactly this type of interference, and have been looking into doing the same thing.
However, last week while working on the door we discovered that that hinge has a wobble - but only when the door is very nearly closed. In other words, if you work on the door when it's fully/close to fully open, and move the door back and forth, there is no up/down wobble. However, when the door gets close to closed it moves up and down about 1/2".
My question - has anyone else had this problem? I've ordered a new hinge from La Jolla - should I expect that to fix this problem? If not, I'd hate to go to the trouble of getting it sprayed and installed only to find I have to scallop the glass anyway.
Any thought appreciated.
