double brake vacuum from carbs
deQuincey
Quousque tandem...?
interested in this linkage for the brake vaccum
have you noticed that apart from the primary vacuum from the front carb (manifold, yeah) there is a secondary vacuum taken from the rear carb that is added to the vacuum tube ?
any thoughts ? improve braking ?
remark: if the pic is small, see it in this thread: http://www.e9coupe.com/forum/showthread.php?p=54211#post54211
In the US, the connection on the right carb and a corresponding connection on the left carb would have been for a SS EGR ( exhaust gas recirculation) system. ( Pollution control)
Yours- if that line connects after the brake check valve ( hard to see in the picture ) it would hurt both braking and the rear carb operation. It also makes it impossible to balance the carbs independently.
Mine- the right carb tap is plugged. There is no secondary vacumn line or tap other than the front carb/ manifold connection.
ok, thanks !
