E3 (UK) Tool Roll
E3_UK
Can anyone confirm if this tool roll would have been supplied with my 1972 UK spec' E3 2500 ?. The spanners and plastic screw driver handle are all stamped West Germany, there are no markings on the adjustables or spark plug socket. Not sure if the 17mm spanner should be bent like this, presumably not although it shows no signs of having been deliberately bent :
That's a 2002 tool roll, they are much cheaper in appearance and fewer tools obviously. However, the 2500 came with this tool roll per the parts book, I think 2.5CS was the same.
Thanks. Had a look on Realoem and it does show this tool roll so looks to be original. I guess I should straighten out the 17mm, I have plenty of my own Frankenspanners to use !
It is original for a 2002 or your 2500. The 17MM came bent from BMW, on a 2002 it is used to adjust rear drum brakes!
Phew, thanks, was just about to put it in the vice to straighten it !!
