E9 door seal
It's glued into the contour of the end of the door
2XLO3_41R71dFL04LYJIrQrFDxAxbez7hI3jwg5XbXSsv7w_oqYw1Fy7xQk6YbjZT5DjXKGHJt8d5eQSlH5qd3dAN6SOQwzVfGaV5ROrlUjBFsXCXdY4WDSJ4ntLxW2ArKNZ2AqVfCBM-zUfvE5dAxXzwoMWdTogCfKFAG47gNTpGh_UDmKzO7aXruTI05jllNcGsSmnrHuyLOc6n0I3SlL_9OEdUsQBs5nyBm830E54YEm7F0Q1rJKxBujA1uiDeKNTWZp8OapqmsJ5HtkdA5qXvPmHIABKyctP9mcDBXwbj1Dql4pL0Hn2p84wjx9_-KbZy0Ym5R-N0EcXDqV36MKCKGtRVQ6KUPkRNyd-8JH68WC_8HbVbiKY3RldFIQly4vry747hUwe9lQGlay7tulNMlHk59NT2Q3GyokWccSz_SGlT9vvaUiupK4o7UdFw0ODgxnCc2Ncp_nGHiQXwRUpndf0IWXZw635RxaZbzwbtJ6J_9lxOs89zYmHgJrio1hG0dQbQBhuBRE2_Yox-nzNCOCOpW1pkWusvb7QO6QnlQ-lviJEcQNbmVjx-bNww9oX-g_gh1J5EiYYaA9tUs6ILw1z4I0qWDl_VMguJ4wwRCFwSLPi9JYr2U_8umJWQoWe4HG9s63Hpg1lbWF_FG2piZThxJo7l5H7z1Au07eOEJeh80tndA=w411-h781-no
@RTHLSS1 if those are the ones you need, you might want to buy them from Joachim (both sides)
@Keshav I bought them a while ago from oldtimerteile just wasn’t sure how to fit them.
I am looking for "keder" that comes under door panel. Only found them in black - I have same color panels as @Stevehose on photos
https://www.cs-werk.de/cs-werk-bonn...ertigungen-fuer-bmw-e9/53_1_bmw_e9_keder_set/
I can also have them made here localy but I dont know if I go with black or blue color - but blue will never be same as panel color so I might pop out more than If I go with black color.
Also wanted to ask what is the purpose of this door seal? Sound proof?
The black keder goes well with dark panels..... amd as you point out, matching the colors with new materials is not always easy.
Yes, those gaskets help lessen the incoming air sound. Thought I’d also mention, as seen in Steve‘s pic, the small plastic cover/ cap on the door latch is very important. Makes the door closing a lot better than without.
I have them if you mean this: https://www.wallothnesch.com/en/rubber-cover-41-12-14.html#zoom-container-layer
Door where closing nicely but now when I put new rubber door gaskets not anymore have to push them hard but they line up perfect.
Yes, those caps and yes, the door closing issues with new door seals is common. They eventually do ’settle‘ down but an annoying feeling to start off with.
Don had recently hinted at certain spots on the new door gaskets where some ’work’ eases the tension. You might want to ask him.
Difficult for me to say in English what I did:
The gaskets on my E9 had to much volume, so I had to much tension closing the door.
So I cutted the "gasket tube" on the long side and removed a string with several millimeters.
I glued it together again with gasket/seal glue.
I did it on the side which is close to invisible / close to the sheet of the body.
It's now 4 years ago and it just works. The optics of the gasket is like "factory" / no so overblastet
