E9 ECU compatibility... Info needed
bibendum
New Member
Hi all,
My name is Jason and I'm from Jakarta, Indonesia... Long way away :grin:
I've got a '73 E9 CSI... And I'm currently having an ECU problem here and was wondering if anyone know if:
ECU with Bosch # 0 280 001 007 is compatible with # 0 280 001 102 (I believe this is from an E3 3.0SI)
Thank you in advance...
Regards,
Jason
Jason,
There is an excellent reference source for all things "vintage Bosch". Go to www.automotive-tradition.de/en Get yoursefl registered and logged in and then go to the "Knowledge" area. Dig around the several types of searches available and should be able to answer your question. The PDF's the search engine pulls up are in German so a bit of manual googling-translating will be required.
Jason,
Got the infos I need Luis, thank you for the tip
Jason
