Wow!
Carl Nelson springs can be installed while driving on a bridge against traffic and the car immediately grows a side mirror, Marchal fog lights, and Alpina rims!
Carl should be canonized alive.
Wow!
Did the car's handling change in any noticeable way?
Yes. I have CN springs and neg camber plates. The car handles way better at speed, hiway on and off ramps are much better handled, less lean, car is flatter in the curves. The car is rock solid at 90+ mph and no longer catches wind like a boat with the bow out of the water like before. The Bilsteins make the ride firmer, the springs didn't contribute much if any to that aspect. And it looks badass when lower and properly stanced.
On the topic of 16"s: I started rubbing after lowering it. Im running 205/16's on the front, and my front wheels need to come in 5mm or so. I'm exploring options with machine shops to take out some of the wheel to bring them in a hair. A thought for those who are looking for bigger tires and a lowered stance.
Rolling the fenders won't be enough. Rather than pulling them, I'd rather machine my knock off wheels.
Link opens for me
my experience: using CN´s + Bilsteins B6
before:
after carl nelson springs
before
after CN springs
i like the stance very much
more actual pics
another one to compare, see now the before setting:
similar photo of before
see thread:
http://www.e9coupe.com/forum/showthread.php?t=14519&highlight=springs
yes, to all of these, Steve, but,...there is always a but...
now my car´s rear axle feels less stable in really Sharp bends at high speeds
i mean, she tends to drift more than before
there is a reson for that, once you make the front axle more rigid, you dont let the body transmit the energy in the same way
it is not noticeable for "legal" speeds driving but if you go to circuit ...be aware :-I
hi
what is the tire size front and rear of the red coupe]
thx
205/55/ZR16 Front
225/50/ZR16 Rear
Google "tire calculator"
The wider the tire, the taller it gets. To keep the same height, you get a lower aspect ratio tire
To put it simply - the aspect ratio is a percentage of the tyres width. I have 9.5. 40 AR on the rear and 8 .40AR on the front. 9.5 X 40% is 3.8" and 8 x 45% is 3.6" so nearly the same.
thx steve
why does the rear tire need lower profile than the front? would that make the rear end higher?
vorarat
just think how much easier it would be if this were true. you wouldn't have to worry about throwing the speedo / odo off by changing tire sizes.I never understood the rationale behind this... It creates a moving target that makes things much harder than they should be.
Seems to me that since the second number describes the "height" of the tire, it should be either a fixed number like the width and wheel diameters are or, if it is a ratio, it should be a ratio of something that relates to the "height" like the wheel diameter. Not the tire width...
