EI Dizzy from Mrfiat
jamesw
Houston TX
Has anyone used one of his EI Distributors for the M30 engine? I think the company is actually called Everything Alfa but I originally saw the listing on Ebay. They look pretty good.
http://mrfiat.com/part.php?item=Car...8003.0CSLCSCSiLA32065206Elct.Distributor.html
I use something similar on my Fairlady and it's fantastic. You can run a 12V MSD blaster coil w/ a much bigger spark plug gap and the engine just runs so much smoother.
Cheers
James
consider 123 ignition
the new distributors from 123 ignition are gaining popularity within the Jag club.
I know of quite a few E-type and xk owners who've used them and highly recommend them. They are a bit pricey, but you get a lot more than just a points replacement (e.g. Pertronix).
http://www.123ignition.nl/id/56.html
Thanks! It's great to have the manufacturer's website - with installation manual :-)
I am going to go for it. I love the one I have on my Fairlady.
Cheers
James
Ordered it today. Where is a good place to get plug wires, spark plugs and a decent coil - all at once?
Cheers
James
You're killing me John - where did you get your EI dizzy for $450?
Thanks for the tips on the wires folks.
Cheers
James
Received my EI Dizzy today. I'm a bit frustrated because I don't have the correct hex key to open it and hook up to my computer. So off to the hardware store!
Programmable centrifugal advance and programmable vacuum advance/retard.
Combine this with a good set of different carb jets, and a dyno and I bet you can get a carb'd car running almost as well as fuel injection. Oh and probably a LOT of "know-how" required too.
Regards,
James
