electric radiator fan conversion completed
Still running the dual Spals; had one minor issue; engine started to heat up quickly on the xway; stopped and restarted problem went away.
Otherwise has worked well. Have the fans on a dedicated relay with the controller tucked away behind the driver side headlights.
Looking for pics, otherwise will take some tomorrow.
R
Thank you RJ.
A few more questions:
- Are you using the stock e9 radiator?
- Any specific reason you decided to go with two 11' rather than one 16"?
- Did you build a shroud?
- Where are you hooking up the temperature sensor?
Thank you.
Stock radiator; Used 2 fans because I was able to get a package deal with the controller- plus overall fan volume was higher in essentially the same space.
Had a very simple flat shroud built; forcing air to go through the fans, with additional rubber covered flaps that open up at speed- saw a similars setup on a Jag XJ-S V-12.
Biggest difference is the noise level. The stock fans were screaming loud.
IIRC, Sensor branched off stock thermostat plug.
I still have room for a larger radiator and if I keep the car, may do that.
R
Dual Fan Install Photo
Bo:
Take a look at the attached pic- the installation was tight, but i was able to squeeze both fans in by staggering them; I had the shroud fabricated as flat as possible so as to maintain easy access to the fans.
Hope this helps,
R
Shroud was custom; not enough room for the Spal shroud, and yes the placement was to clear the compressor.
"strip" is a length of rubber weatherstripping to get a better seal over the top of the radiator/shroud.
R
electric fan
I run only an electric fan in my '72CS as well. No mechanical. Comes on when needed, about when temp guage hits 3 o'clock. Efficient, dependable. Just installed new water pump and will be curious if there is any change to efficiency.
Mike
