Many threads on this, try the search function. Are you sure the motor is not working? Press the switch while feeling the motor shaft through the access hole in the door panel to see if it moves a little when switching up/down and is just stuck. The issues usually are the window tracks (dirty and old grease has hardened) and stripped gearboxes as a result. Motors rarely go bad, but you never know.
