Also make sure the switch is "clean" (low resistance). Sometimes it is best to take a switch from the rear window that presumably has seen less use. I assume you'll try it with unloaded motor first (dettached from the window regulator).
Interesting. The armrest and console switches are presumably wired in parallel. The only way you would short the circuit is if one of the switches (either armrest or console) does not quite open when in the idle position. Could be that it is tired mechanically or has lots of deposits making it conduct (hard to believe). I assume the fuse blows when you operate one of the rear windows, not just by sitting there wired the new way. If that is the case
the bad switch is the one you are not actuating when it blows. (If it blows when you actuate the console rear right window, then the right armrest is bad, if it blows when you actuate the armrest switch, then the console switch is bad).
Pull the suspect switch and measure resistance between all pairs of pins
when the switch is not actuated, should be infinite resistance (open) for all
of them.
If it blows just by sitting there, you don't need me, you need an exorcist.
Which of the 4 motors from the E28 were used. I hear people say that only the rears work on our E9. Did you just use the motor, or the frames as well from the E28?Thanks to this thead I've almost completed the retro fit of the e28 window motor to the drivers door regulator. The wiring which I though would be the hard part was actually easy. I used the green and blue leads from the wiring harness and connected those to the 2 leads of the new motor. The ground from the wiring harness is not used. The last step was to grounded the 4th pin on the window switch to the cig lighter and it just worked.
I've taken a bunch of pictures along the way with hope of writing this up but I've run into a snag. The gearbox on the new motor is thicker than the old style and when mounted contacts the inner door frame before the bolts can be fully tightened on the regulator. It will actually operate the window but I really don't want to leave it this way. It seems that several other including indyken46619 cutout the door to clearance the motor.
In this picture the black marker highlights the contact point and the portion of the door panel that needs be removed.
This image more clearly shows how far the mounting bolt is from reaching its base when the motor contacts the door
Has anyone been able to complete the conversion without cutting the inner door frame?
-Kurtd
