Electrical problems in my 3.0CS
You can also unscrew them with a correct size Snap ring plier. If so, push hard so not to have it jump out and make scratches.
If you happen to have one already, it saves you buying a tool that you need only once..
Erik--You are the Forum's official Tool Man. If that special tool had a red handle, you would have it in your trunk toolbox already.....:)
The EQUUS # 3721 battery & charging diagnostic tool is a safe way of seeing if your charging system is working correctly while driving. Plug it into a cigar lighter power port and read your voltage and check your charging system at any RPM. I found it on eBay for about $35. My lighter is not wired up,but I have a power port in my custom console.
https://www.ebay.com/itm/3737884250...g%3D|ampid:PL_CLK|clp:2047675&epid=2285500707
It looks like the same tool that similar age VWs used for their light switches. I used to have one, decades ago with my VWs. It shouldn't be too hard to find.
Ah, here's one.
I went to their site and bought the tool. It has tangs that are a tight fit. Pretty rough machining, but a little hand file to soften the edges and the tool will safely remove the headlight switch bezel. Thanks for the link.-----Drew
Love the wood e-brake handle!
The wood is curly Hawaiian Koa to match the dash. I bought 2 billets of the wood on eBay some time ago. They were glued together and the furniture maker even duplicated the finger grips on the bottom.
https://www.ebay.com/itm/373788425063?_trkparms=amclksrc=ITM&aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=237069&meid=98bc0b62ff0443138583702a852aa923&pid=101195&rk=1&rkt=2&sd=325006380484&itm=373788425063&pmt=1&noa=0&pg=2047675&algv=SimplAMLv9PairwiseWebMskuVariantAspectsSeedMskuPromotion&brand=Innova&_trksid=p2047675.c101195.m1851&amdata=cksum:37378842506398bc0b62ff0443138583702a852aa923|enc:AQAGAAACUPrnh3CHWHKk5OU3mD%2F5qWpMngYIg9v43F3GstKWNvAJtKS3OmxCj4wQbxkJZ%2F1dK2Gkky43z46Nj4RYeL667jjqlfbrweOs%2FmiZRYY08VzxYautDiizyvdVfEmw7fskjyewnTekGFvR%2BERsUC8KxQRWIrTkvQqv9cIdr4kqKEh4ACo9wYCIduJzJwIj5qStF6k6dRwr4rGOWyZc8176JpvvqRBL%2F8OW6o6AWCV4K5O6A0Kn4Oi3%2F6Cy2TNl%2BWt1WY4Su81uwafC1msa3czRUOqn1%2F6yVgIyKBqNSvhh%2FrWtOZheZN%2B%2BqZHAZYTJTAOnGKJp54rgJvijx1B1gh4IBc3TZUFL4PEFXzD4%2FJoSd%2FuqdI%2FfJFBCXirAnbHwpaufM%2B4jxzwZcpfLPWX2Koc%2FwvdUpHnm3jwfDHI7pYnASHuluErHyii0DaGISaWDdhPDlSp7S37tCNnlIsIe%2BcvhWoYrt0ADVPjtrOQqstHXCDlc2ds0ZpP8iYnYz1323FfOrOIdczatObPNSPze%2FTArTYZ3kLtYDRgVD86EdIGb9nuZcoBM6%2BhfvKoTFr%2BZUYNThABbPFpD1tPoms6e51j8WZw%2BzsQcuuSjcVO0yzNvXm5YQmfDRYfnKzhZfY1Y6xHJmajMwzqQAQ2MmFeRfvLqBimElgzNdskHC52hTtUDb7rvKjyPQT8Fcdgir7XXcjUBQnAx7CyBpmI35WSg1FWacYC%2F5hlC8BKQAFWCt5oUObv%2FL6rhRnav5qgDZsv8Y7H0r0FTKChxOAnhmtROy0XyMlg%3D|ampid:PL_CLK|clp:2047675&epid=2285500707
I like this armrest idea it is very nice
I've got some Monkey Pod wood from a felled tree from when I lived on Maui. It's not as nice as Koa but I'll make a shift knob and hand brake enhancement and see how it looks.
