eltonjohan
I'm depressed right now
I basically been living in the garage since three month pimpin' up my e9. Engine and transmission out, repainting the engine bay, totally renewing everything on front axle, steering etc (I will hopefully come back with some pictures of this later).
I have also been renewing some parts in the engine, like rocker shafts/arms, valve stems gaskets etc.
Today was the big start up day. The engine started at first attempt - happy days! But when removing the valve cover for final adjustment of the valves I noticed that it was full of glycol/water in the oil!! The glycol seem to come along the one or two rocker shafts. Ok, removing the cylinder head again (puh) and having a look at the head gasket. It looks like it has hardly been compressed (?). The red "lines" on the gasket where not flattened as they usually are after tightening the head bolts. According to the book it should only be tightened to 70 Nm which seems like a quite small torque. Is that really correct?
I hope some of you have some good ideas to solve this problem!
To sum it up:
-The engine wasn't having any problems similar to this before.
- I have not damaged the head or block during this period and they don't seem to be uneven.
- The oil is totally mixed with water/glycol after only apprx 2 minutes of running
- No oil in the glycol.
Oh, this turns out to be a very long post, sorry!
thanks
/Johan
To sum it up:
thanks
/Johan
