I don't think that this is a bad question. There is a hole just above the starter that is cast into the block that you can use as a lift point at the rear and at the front, I usually go around the intake manifold between #1 and #2 cylinders. There should be a hook bracket at the front as well but not always easy to set up. Others may have a different idea but this works for me
Thanks, rick
