How easy is it to remove the block with the trans staying put? This way I dont have to remove the exhaust etc. Do i just undo the bolts at the front of the bell housing and slide forward and up!?
Thanks,
Rohan
Thanks,
Rohan
Not sure why you'd do it that way on an E21 (4 cylinder anyway). It comes out easily as an assembly. VERY easily. I could probably swap one in 2 hours. Which is about as long as it takes to remove the two starter bolts.
Also, The E21 transmission is quite a bit lighter than the E9. Best to have at least 2 people if you're hand lifting any of them.
You must be very fast removing down pipes, guibo, clutch lines, backup wiring, heater/coolant hoses, radiator, mounts which all must be undone.
Steve,
Is the hood really finicky to reinstall?
Some of you espouse dropping the whole front end. In theory I could just roll a work bench under the car and drop the whole front end assembly by lifting the car up (car on my lift). But that would require more things to be disconnected (suspension, brake hydraulics).
Exhaust: it's just 6 cristy copper down pipe nuts, the trans hanger (2 bolts), and a few rubber hangers at the back, and the entire exhaust drops out, right? The prop shat probably takes longer...
Finally, when draining coolant I hate cleaning up whatever spills or splashes out. My oil drain pans are all too small (8-10 qt). My local HomeDepot has 36" diameter aluminum water heater pans on sale for only $12. These seem like they'd be big enough to catch everything. I just bought one and it should also make a nice 'basin' for degreasing larger parts like a diff or for putting under a motor that you are disassembling. I might buy a second one and add attachments so it secures to the feet on my engine stand.
John
