My current engine has what I think is some kind of piston slap and a lot of ring blow by entering the crankcase. The car still daily drives but it rattles pretty bad if I get on it hard.
This summer I will be swapping another engine in from a later model car... Ive had the engine sitting for a number of years and cant remember if its a b34 or 35.
I intend to swap over the intake, front cover, cam and exhaust... from the e9
Are there any surprises I should consider other than the possibility of the need for a bracket for one of the engine mounts? Anything peripheral you would recommend changing?
Trans should bolt up? problems with cam chain? Ive been holding off on doing this for awhile... lazy!
Any input is appreciated! Thank you!
