cal csl
- Messages
- 27
- Reaction score
- 0
auxhilary air valve problems
Hi guys, I have a 72 csl which i am having problems with the exhilary air valve not fully shutting off when the engine gets warm.
I have put in a new air valve, filter, stainless water pipe, thermostat (80 degrees). Also have slightly bored the fitting the air valve attaches to allowing better water flow and fully flushed the engine, radiator etc.
The result of the air valve not shutting of is that the engine is idling too high. At the moment the idle screw is all the way in just to get it to idle around 1200 rpm.
Any suggestions on what else i should try would be great.
thanks
Cal
thanks
Cal
