fan clutch on 3.5 m30 conversion
503recheck
portland oregon
I am using a new style waterpump with spin on fan clutch in a new installation fo a 3.5 motor conversion and the radiator is really close to the fan( i think the fan is off a 1990 735 with spin on fan clutch. Is there a better fan blade and clutch arrangement that is still spin on that maybe fits a little better. What arrangement are other people running? any replies are appreciated
I have an M30B35 in my Bavaria and ditched the mechanical fan altogether. I use a 2-speed electric fan setup from a 90's 325 and I never have had any temperature control issues at all.
Old trick- radiator rubber mounts are U shaped. Cut the leg off the front and shift the radiator forward. Slip the piece on the back side.
Wrong fan, wrong fan clutch.
Go with this setup....
11521723027
Uro Parts (Alternate Brand)
Fan Clutch
For models with spin-on fan clutch not bolted to water pump
http://www.autohausaz.com/search/pr...983&cid=16@Cooling System&gid=6812@Fan Clutch
11521271846
MTC
Fan Blade; 420mm with 9 Blades
1 per car.
http://www.autohausaz.com/search/pr...1983&cid=16@Cooling System&gid=6808@Fan Blade
Available for 50 bucks for the set.
Try autohausaz or rmeuropean
Don't forget your discount code....
http://www.ultimatecoupons.com/coupons/rm_european_coupons.htm
Good....
Advise. I had a slight hiccup in this regard myself. sfdon set me straight with his tried and true recipe and now all is good in the cooling world.....thanks Don!
fan clearance issues 3 row radiator
determined that I created the tight fan clearance when I opted for a 3 row radiator when I had my copper radiator rebuilt. I was asked if I had clearance by the radiator shop and forgot during the months between recore and install. I tried the fan and clutch recommended by sfdon and the fan was offset and the clutch was the same I had. I am trying to cut down the size of the nut on the clutch and using the factory blade out of a 1990 735 which has the mounting centered in the offset and the blade diameter is the same as the one recommeded by sfdon but which has the clutch mounting completely offset to the one side. If this does not work I will probably consider electric fan. Word of caution when considering 3 row upgrade from original 2 row radiator
With such tight tolerances you might check the condition of your engine mounts. If they are old and soft then the engine could potentially move forward and make contact with the radiator. I am not sure what kind of tolerances you are working with...
Sorry for your fitment problems- I only use 2 row radiators. The 9 bladed fan and a good fan clutch means the 5 bladed fan and the triple row radiator isn't the best solution anymore.
Hmmm...
The good heads I talked to when I had my radiator out and repaired said two core is best. These are third generation guys, know their stuff passed on from experience of the elders.
Makes sense across the board. The two core passes air more efficiently to the engine bay.
As I have said, heat soak can be an issue. I used sfdons recipe for the water pump and fan clutch assembly and restored the two core. Way to go....in conclusion a well built two core is the best IMO
With the radiator removed (3 Row Radiator) I mounted the fan and fan clutch assembly to the water pump and then measured the clearance between the back of the fan and whatever it was closest to (so I could move it back a bit). I then removed the hub which bolts to the front of the pulley and machined down the forward end and the slot so that I could have the fan just a tad back towards the engine from the original position.
Works Great!
FYI- I spent the morning measuring a dozen radiators and installing a spin on clutch / pump/ fan.
Old style 3 row is 50 mm at the top crossbar and slightly less below that at the core.
New style 2 row ranges from 35 to 40 mm at the top and slightly less at the core.
Went with electric radiator pusher fan in front of the condenser
and deleted the fan blade/clutch arrangement completely. Can be found under electric radiator fan thread
