Feedback; Side Marker Lights
Doug
Did you delete the driver-side door mirror as well? I would think that this may not pass inspection in some states.
Can u share a pic of the left side of your coupe.
Bez,
This is an older pic before I replaced the doors, had it repainted, and replaced the bent chrome caps on the doors with the straight ones from your parts car (thanks). I will need to take some newer pics.
Inspections are not required in Florida since they did away with emission testing so it is not a problem. Hope I don't did pulled over and ticketed on the trans continental drive!
Doug
Paint completed. Side markers deleted
Engine repaired... check
AC updated and blows cold...check
Car Painted...check
Side markers deleted and trunk and engine compartment completed... check
Ready for reassembly then new interior Wood, vintage radio, and tires next.
Can someone recommend tires?
Car Painted...check
We have been beating this one to death for the last few days. If you want tires that were the standard period correct michelin xwx then Coker has then for $450 each. If you want a good looking tire then the Vredestein Sprint Classic at about $270 each. the original size was 195/70 14 and many think a 205/70 14 would work nicely.
