fire extinguisher
according to my experience, not very well
i have seen that the plate he prepared is flat, if you compare with my setup that is slightly bend backwards, his plate will put the extinguisher too far frontwards
IMHO
My setup is not nearly that elegant. I merely removed the carpet covering the passenger seat structure, punched four holes in the carpet, and threaded two large zip ties through the carpet piece, each running through the upper holes of the extinguisher bracket, through the front of the holes in the front of the seat support structure, looped around the top of the seat support, then back through the carpet and zipped up.
