firewall insulation by brake
aearch
pleasant hill , ca
fs firewall insulation by brake
received an extra firewall insulation located by the
brake booster
if anyone needs it let me know before i send it back
it was $108.00
ok
How easy is that insulation to install? Do I need to remove grommets and disconnect wires?
What it looks like 'in situ'. You couldn't get it in place intact except by removing the booster support/pedal box, but as DQ says, if you split it, you would be able to. However, it's very crowded and it looks difficult without removing some equipment but I've never tried it that way.
great pic
thanks luis for the great info
plus you resolved my wiring issue
would be good to see the other pieces
