Flag mirrors loose wont stay in place
chope97
Silver Spring, MD
Both of my flag mirrors move too easily. I took the passenger side mirror off and tried to tighten the inside bolt. It did not make much difference. Can I add a small washer to make this tighter? What are other options?
Sounds like the issue is the mirror stays attached to the door but is internally floppy rather than being loose on the door?
Check to make sure the mirror is in the right position on the base. If the base is tight to the door skin then it is likely that the mirror screw is not tight enough.
After adding the mirror to the passenger side I found that I had to really tighten the screw that attaches the mirror to the base fixture otherwise it was so loose it had a lot of movement.
It's not entirely clear to me where they play is situated, between which 2 parts.
So from top to bottom (literally)
- Is the glass rattling inside it's stainless steel casing? Then perhaps the spring behind the glass is rusted or askew (though unlikely, as spring steel is quite rust proof)
- Is the stainless steel flag loosen on the 'pole'? If so, there is a ball joint with a screw that tensions the ball joint. It is behind the glass if I remember well. I tend to think this is screw that you mention @chope97 ? If so, A washer may help to spread the clamping force over a bigger area, giving more friction in the ball joint interface.
I tried to tighten one of these, and it snapped.
Also, i understand that the ball joint rotates easily: tightening the screw increases friction, but there may be other ways to achieve the same: it may be increased by removing any oil/grease that may be present. I think the ball joint is seperable to clean it? If not, just a rag and clean while rotating the mirror to it's max positions, exposing as much as possible the ball joint surface?
- Is the 'pole' of the flag loose on the inner, non visible die cast foot?
Then there is only one adjustment allen screw at the rear of the chrome part that clamps it to the die cast foot. If tightening that allen screw doesn't help, something in that interface is bend/broken.
Last interface is between the door and the die cast foot. Originally the diecast foot uses 2 screws that go into the funny captive nuts that you can insert from the outside, turn 90 degrees and lock in place for the screw to be fastened. These funny nuts are weak. And the door skin is weak. If you walk into a mirror, good chance that either one is bent. Disassemble, check for deformation, retighten the screws of n the die cast nut if needed.
Good luck.
Let me make it clear the base is fine, the adjustable mirror part that you adjust to allow yourself to see what is on the side of you is easily moved with the slightest touch. If you take the mirror off the car and turn it over you will see a bolt that has a spring under it. The bolt screws into the bottom of the flag stem. The more you tighten it down the more it engages the spring which is suppose to increase stiffness between the flag and the base.
