This just cropped up. Nothing has changed (other than it's been a little cold in the garage) -- foot brake and parking brake both working fine. Fluid level OK. Is this a known fault? Any suggestions appreciated!
I recall that light doubles up as parking brake engaged and brake fluid level. I assume flickering does not mean intermittent... If flickering means barely coming on
I would suspect either the brake fluid sensor or float are failing, or the parking brake switch is shorting. My guess is that is it the brake fluid, willing to bet 9 dollars...
