Hi guys
My high beam stalk is floppy (I know, that sounds wrong) - it activates high beam but there is a lot of play in it. I could always live with it but wondered if it could be repaired?
Thanks for any advice
Mine was floppy from other drivers thinking the left is the turn signal and brut forcing.
One day my daughter drove it and just broke it when signalling a turn...
Advice? Replace it and do not let my daughter drive it.
Had this very same situation. As has been mentioned, it is possible to take apart and re-secure with zip ties. That's what worked for me. Not rocket science. Just kinda fussy getting the column apart and gaining access. The alloy housing kinda disintegrates at one of the crimps. You will see when you take this apart. Once it is in your hands you will see how easily you can make this high beam stalk great again. Good luck!Hi guys
