Does your rod flop all over the place? Do you have a hard time keeping it in the slot?
Then our Ultimate Shift Linkage System is just the answer! Replace all the worn-out shifting components from the end of the shifter to the input rod on the transmission. And, get a DSSR to boot! We have stainless steel DSSRs for all the vintage BMWs from the 60s to the 80s. We have both early and late E3/E9 versions for both 4 and 5 speed transmissions. They all come with oil-impregnated bronze bushings, the latest connection joint at the transmission input rod with an oil-impregnated bronze bushing, stainless steel clevis pins, clevis pin clips, a tube of Super Lube and our famous Wedgie Tool to make the job go faster.
And, during our Black Friday sale get 10% off on any of our Shift Linkage Systems!
www.2002sonly.com
The Ultimate Shift Linkage System for M30 | 2002s Only
Does your rod flop all over the place? Do you have a hard time getting it in the slot? Then our Ultimate Shift Linkage System is just the answer! Replace all the worn-out shifting components from the end of the shifter to the input rod on the transmission. And, get a DSSR to boot! We have...
