For Those who need / want new VDO Series 1 gauges
rsporsche
Atlanta, GA
Guys, for anyone wanting to add VDO gauges at sometime in the future that match the gauges in the coupe - black face, white numbers, white needle and a chrome rim ... the VDO Series 1 is the best choice. here is the downside, VDO doesn't make these anymore and what is still available in the market is what you can buy. the next best thing is the VDO Vision Chrome, which is the same but has red needles ... as @Stevehose said, you can gently pry the chrome rim off and paint the red needle white. I bought the 250 water temp, the volt meter and an electrical 100 psi oil pressure sender (the last one)
i just found a set for my car from Timmy @ Discount Gauges www.discountegauges.com (thanks @Stevehose for pointing me in his direction). so i asked Timmy what he had ... so here is the list
Series 1 250F Water Temp
Series 1 Fuel Level 10-184 Ohm Sender Required $79.00 1 in stock
Series 1 Fuel Level 0-90 Ohm Sender Required $79.00 2 in stock GM and some Chrysler
Series 1 100 PSI Oil Pressure Mechanical $79.00ea. 1 in stock
Series 1 150 PSI Oil Pressure Mechanical $79.00ea. 1 in stock
Series 1 12 (8-16)Volt Meter $79.00ea. 2 in stock
Series 1 12 (8-16)Volt Meter $79.00ea. 4 in stock Has Green to Red indicator Line
Series 1 Tachometer 7,000 RPM 85mm Diameter Orange adjustable Rev Pointer $229.00ea. 1 in stock
VISION CHROME
Vision Chrome 250F Water Temp $69.00ea. 5 in stock
Vision Chrome 300F Temp $69.00ea. 5 in stock
Vision Chrome 80 PSI Oil Pressure $69.00ea. 4 in stock
Vision Chrome Fuel Level 10-184 Ohm Sender Required $69.00 6 in stock
I have the Series 1 gauges in my car (Note that the AFR gauge is not a VDO gauge):
I have the VDO 360 007 sender which is 80psi for the gauge and 8.5psi for the idiot light. M12x1.5 thread for direct mount to the head.
