What is the best way to re-align the front bumper. One side (right is higher than the other, probably a bumper hit)? Is this a major job (body shop work)? Thank you in advance
Should be an easy fix, though you can drive yourself mad if you're a perfectionist. The bumper brackets that pass through the lower front bodywork are anchored to the subframe with two bolts each. The bolt holes in the frame and brackets are oversized for adjustment. Slightly loosen the front or rear bolt on the offending side and lift/lower the bumper on that side until both sides are even. Tighten bolts. You may want to prop the bumper up at its desired height before snugging down the bolts.
Now step back and observe that left vs. right heights aren't perfect. Repeat process until 15 minute project consumes entire weekend.
