Front suspension... where do these go?
Bmachine
Northern California coast
I looked in realoem and on my disassembly photos and I can’t figure out where the two approximately 80mm steel disks go. They have a hole in the center which fits the upper part of the shock absorber so I thought they came from there but I find no trace of them in the parts diagram...
http://www.realoem.com/bmw/enUS/showparts?id=7013-USA-12-1973-E9-BMW-30CS&diagId=31_0451
And while we are at it, on that page, what is the difference between #1 and #2? 2 seems to be the rubber pad but then what is #1? My car did not have anything there.
Any thought? Thank you
These guys:
Just speculation from my side, could the steel discs be part# 13 in the diagram? I dont have them on my car, so I’m not sure at all.
Thank you Robert and Don. Now that I look at it it seems obvious that it is indeed number 13! Doh!
But then that means that it will sits right under and against the main cup #3? Is there no gasket or washer in between them? I assume some grease should at least be put in there, no?
As far as #1 and 2, I see what you mean, Don. The diagram isn’t clear that the spring goes between the two. I thought it was trying to say that they were together at the top.
Aha! No 13 either! I thought it was just no 14. Ok that makes more sense. I suppose 13 was there to “cup” the foam bumper 14 on the original setup.
Thank you Don!
Dang. One more mystery part... I have these two cup washers in my front strut parts box. They look like they would be going outside of a bearing to keep the grease clean but referring to that same schematic above I don’t see any mention of it. I’m guessing it’s going on the upper strut bearing, but above or below?
Thank you.
So to wrap this thread, this is the order of parts for a bilstein set up. (Springs not shown)
Doing the same job and that is how I have it set up also....except is that a neoprene washer (7th from the right)???? that I don't have that!
Crap. I had a feeling it would be a good idea to post a pic of all the parts for confirmation and here is why... So the cup one is on the diagram after all. I guess I need to take my struts all apart again.
But where does that "nylon" one with a slit go then?
And Don, which pic is wrong? Then one on the WN page you linked?
I have never seen a nylon washer.
I believe You have the order correct in the pic.
